PorE VB API
  • Thread starter Thread starter sureshy
  • Start date Start date
S
sureshy
Guest
How to connect with ProE using Proe4.0 VB API . . . ????
Edited by: sureshy
Dim asyncConnection as pfcls.IpfcAsyncConnection
Dim Casync as New pfcls.CCpfcAsyncConnection
asyncConnection = Casync.Connect (DBNull.Value, DBNull.Value, DBNull.Value, DBNull.Value)
session = asyncConnection.Session;
'Function CCpfcAsyncConnection.Connect (Display as String [optional], UserID as String [optional], TextPath as String [optional], TimeoutSec as Long [optional]) as IpfcAsyncConnection
Hi forstudy3.
Am using WF 4 and Visual Basic 2008 Express.
I need to start a new proe session in non-graphic
mode.Here's the different versions of the code i've used:
CCAsyCon.Start("D:\ptc\proeWildfire 4.0" + " -
g:no_graphics -i:rpc_input", ".")
CCAsyCon.Start("D:\ptc\proeWildfire 4.0\bin" + " -
CCAsyCon.Start("pro -g:no_graphics -i:rpc_input", ".")
Its not connecting with any of the codes.Showing these
messages in the output window:
A first chance exception of type
'System.ArgumentException' occurred in
ConsoleApplication2.exe
'System.Runtime.InteropServices.COMException' occurred in
The proe vb api is referenced correctly.
Can anybody help out?
1)Have you checked environment variables "PRO_COMM_MSG_EXE" and "PRO_DIRECTORY".
2)start method should get called as - aSynchConnect = (New CCpfcAsyncConnection).Start(exePath + " -
Yes the environment variables are correct.And my actual
code is:
CCAsyCon = New CCpfcAsyncConnection
asyncConnection = CCAsyCon.Start(exePath + " -
When i run this am getting the error -
"pfcExceptions::XToolkitNoLicense at
pfcls.CCpfcAsyncConnectionClass.Start(String_CmdLine,Obje
ct_TextPath)"
Any clue on this error?
Thanks.
Edited by: hijacker
"ToolkitNoLicense" Seems you dont have toolkit license.
I have all the required licenses.I even have a licensed
Pro/Toolkit.
Apart from that what else is needed?
Okay.The above error doesnt show up when i restart my
Flexnet Server.But then after each execution of the
Program,it throwsup the error.Everytime i need to restart
the Flexnet Server.
Edited by: hijacker
actually it should not supposed to work this way. Are you getting license exception for all Pro/Toolkit types? or Only for vbapi? What happens if you restart license server and run , does this runs succesfully?
Also note PTC distributes seperate seat for Pro/Toolkit. You can check available ProTk license by running ptcstatus batch file.
Hi.ThankYou for your reply.
I've resolved the error.
I forgot to end the session.My license is for a single
user.So whenever a sessions overlaps,an error popped up.So
after completing the operations in each session,the session
needed to be closed and i had forgot to do that!
Working perfect now though a bit slow!:)
Still a doubt persist..cant we use non-graphic mode in
synchronous methods cz asynchronous seems to be pretty
slow?
