PMI Section View in Assembly Sequence
Barnon
I created a new Assembly Sequence from a PMI Section view and the new sequence showed the parts sectioned from PMI. Problem is I wanted to show another part sectioned but even creating a new sequence still shows the original PMI section even if I delete all the PMI views. I can't seem to delete the sequence view. I spoke with the Help Desk, they said it was old code and not meant to work with PMI. Attached is a JPG showing the issue.
I guess I can try promoting components and trimming bodies to show sectioned parts if there are no other options.
NX version 1863
 https://files.engineering.com/getfile.aspx?folder=705ee391-d263-4f4d-bfd2-ca923fc0885e&file=sequence_issue.jpg
I was able to get what I wanted using Assembly Cut........
