pitch graph in helical sweep
  • Thread starter Thread starter kavita_verman
  • Start date Start date
K
kavita_verman
Guest
can anyone plz tell me what is pitch graph in helical
sweep. what is the significance of it in the context of
helix. i have to make spiral around the periphery of a
cylinder. I am not able to understand the pitch graph as to
what pitch i have to enter. the picth defines which value
of the spiral? if needed, i can send the drawing or the
model.
Edited by: kavita_verman
pitch graph defines pitch of spiral at different distances.
for example, you can specify pitch at different angles.
If your helix length is 20mm.
length(mm)--angle(degree)--pitch value
0--0--x
90--5--y
180--10--z
270--15--w
360--20--p
where x,y,x p are the values you can specify..
u can also enter intermediate angles as required.
pitch: it is the value by which helix advances in length.Just like in spring or thread
Edited by: s_pme20
