mae1133
- Jul 7, 2003
- 61
I'm working on a project where I need to provide forces from a piping system to a structural engineer to design the support system. Attached is an example of one of the supports being designed. The fluid being transported is water at 20 psi. The velocity of the water is 9 fps. This is in an open system where flow is transported from one open tank to another. The piping is welded and flanged SS. Any valves on the system will be butterfly valves so slow closing. I know this should be quite straight forward, but can someone show the methodology in calculating the dynamic forces that the supports will need to support? Are dynamic forces a concern? Thanks
