I am looking for a little validation on this as I haven't thought of it this way. So you use CA, mill tol, pressure, etc to calculate a required thickness per B31.3. Using this you select a schedule that has a nominal thickness. An API inspector is telling me that end of life for the pipe would be nominal - CA. From this you can then perform FFS API579 techniques to extend life if so desired. Seems to me like this could lead to premature replacement. Particularly if you do not have beginning of life UT readings to know pipe thickness from the mill. Ideas, thoughts on this would be apreciated.
