RW01
- Aug 22, 2017
- 2
Hi all,
I'm trying to wrap my head around the requirements for pig trap design for ASME B31.4/B31.8 codes.
Firstly, I can't see any clauses in ASME B31.4/B31.8 which refer to the design of pig traps / vessels, so I'm trying to get some clarity on what it means for a pig trap to be designed to these codes.
Secondly, my company has some internal standards which allow the use of the ASME pipeline codes for pig trap design, but require the use of pressure vessel design codes (e.g. ASME VIII) where fatigue loading is an issue. Is it normal for pig traps to be designed solely to the pipeline codes (unless fatigue is an issue) or do they always need to be supplemented by the pressure vessel codes?
Thanks in advance.
Thanks in advance.
