sbmathias
Industrial
- Jan 29, 2004
- 50
I am trying to model a part which has a tab pierced (?) out of it and bent up. I'm not sure that pierced is the correct term. It is similar in process to the old sheet metal can- and bottle-openers, where the tab that catches under the can lip or bottle cap edge is cut from the body of the item and bent out.
At any rate, I have tried a number of things to cut the tab out of the flat part, all of which have given me SW errors. I've tried some of the sheet metal piercing tools, which also give me material thickness errors (I'm using 3/16" material).
It seems like I should be able to use the sheet metal features to come up with a blank, then use a line sketch to cut through the blank without removing any material. From there, use the flex tool to bend the tab into position. However, can't get the line sketch to work (SW error saying that my sketch doesn't intersect the part), and so haven't been able to proceed.
Any ideas, or do I need to post a photo? (I wasn't sure how to embed a photo in this text.)
