Photoworks Render Manager Problem
aczj
Is there a way to remove all photoworks information from a file after it has been rendered. Whenever I click on the Render Manager Tab SW closes and gives me an unhandled error message. It only does it with one file and works normally with all others. This is SW 2005 SP0 on Win XP SP2.
Have you clean your TEMP's out lately? See faq559-884
XP SP2 isn't support I hope you know that. SW may work on it?? but SW recommends that you don't update until SP1.0 of SW05 or SP5.0 of SW04
Scott Baugh, CSWP [pc2]
If you are in the SW Forum Check out the FAQ section
To make the Best of Eng-Tips Forums FAQ731-376
Temp's are clean and I've reinstalled hoping to fix any corrupted files.
I do know it's not supported but we've had it running on several machines in the office with no problems so I decided to give it a try. What's really strange is that it is only affecting one particular assembly that I have never had a problem with until now.
You might be able to run SW but you should not be able to reinstall SW04 or 05, because the Windows installer is a different version between SP's of XP.
To remove a photoworks material simply click on the photoworks tab and click and expand the Materials folder. Highlight the material(s) and click the delete key.
Do this for scenes etc...
I just removed XP SP2 and reinstalled SW05 yet again, no difference. it has to be something corrupted with the individual file.
That is exactly what I can't do. When I click on the photoworks tab (render manage) in the maager block, it kicks me out of SW giving me the unhandled error. All other functionality (that I use) is normal. I need to remove all rendering completely as if it were never rendered and then try to create the rendering again, if that's possible.
maybe try removing the photoworks add-in and then open the file.
Just a Thought.....
A man should look for what is, and not for what he thinks should be. -Albert Einstein
A person who never made a mistake never tried anything new. -Albert Einstein
Did you clean out the registry when before you reinstalled?
Try opening it up on another machine. This will help rule out it being your machine of the file.
I tried removing the add-in, opening the file and saving it, no difference.
I just opened it on another computer and had the same result.
Any other thoughts on removing the rendering info from the file?
You can't remove the renderings or materials, etc... from the file without having it open ins SW. If it's doing this on another computer the problem is the file and all you can do with that is send it to your VAR and have them send it to SW for a possible repair.
Thanks for all the help guys.
