photorender
  • Thread starter Thread starter vishal
  • Start date Start date
V
vishal
Guest
how to insert any image (jpeg) as background in photorendering?
Thanks in advance
Hello
Try this :
View, Model Set Up, Photorender
Click on Modify room configuration, select the walls you want to add a texture (click on all walls) and click load texture, then search for your picture to add.
Render and see the results
Karavasilis V. Christos
thanks Karavasilis V. Christos
just now some one has given reply the same answer to much earlier asked question (by me) on same topic but in modelling forum. thanks to you also
i have successfully tried it
