Burunduk
- May 2, 2019
- 2,533
Part A has a 22mm bore boss with tolerance of h6(0/-0.013). It mates with a 22mm H7(+0.021/0) bore on part B. Both parts make face contact on flat surfaces designed perpendicular to the boss/bore. The mating faces are designated as datum features on both parts. Should the boss and the bore be specified perpendicular within 0 at MMC to their respective flat face datums to "protect" perfectly perpendicular Virtual Condition boundaries of 22mm and avoid assembly problems?
