Perpendicular midsurface connections
  • Thread starter Thread starter foresterj
  • Start date Start date
F
foresterj
Guest
How do I connect two perpendicular midsurface shell elements (stiffened plate) together? I dont have a surface to sellect on the stiffeners because they are drawn as one part, connected with the plate. I am trying to compare the differences between using a shell element and a beam element.
foresterj,
If you have ptc maintenance, it is easier to seach the knowledge base than for me to explain it. There will be examples on all types of mechanica problems. If you can't find it, reply and I will try to help you out.
Lance Lie
Lance Lie,
Where can I get ptc maintenance?I want to get the answer of foresterj's question too.
Best regard!
