moe333
Geotechnical
- Jul 31, 2003
- 416
Hi Everyone:
This is not a homework problem! Sorry but this is a little long-winded:
I have Modified Compaction test results (6" mold) and gradation for a SM/SC material that has about 10% retained on 3/4" sieve and 30% retained on the 3/8".
I also have field density tests (some rock corrected some not) so I know what the average compacted dry density and percent compaction is in the field.
I am doing some non-standard settlement/collapse studies where I have collected bag samples of the compacted material.
I want to remold the -#4 portion of the sample in a standard consol ring and do some loading and wetting increments and want to place it at a density and moisture so that it models the compacted field conditions (material with 10% retained on 3/4" sieve).
My assumption (right or wrong) is that the coarse material is "flotaing" in the finer matrix and does not significantly affect the compression characteristics. Given this assumption, I want to compact my -#4 sample to the same percent compaction that the -#4 portion of the field compacted material.
I am thinking of running a compaction test on my -#4 sample and remold it to the average percent field compaction(material with 20% retained on 3/4" sieve). I don't want to base it on dry density since I believe small differences in gradation can affect percent compaction/compressibility.
I'm wondering if there is a way to estimate what the percent compaction of the -#4 portion of the field material is analytically, using oversize corrections.
For example; if the field compaction is say 95% of modified, does this mean that the -#4 portion is compacted to 95% as well?
I may be overthinking this, but just wanted to see if anyone had any thoughts. (Note that I can't do any field testing at this point)
Thanks!
Thanks!
