S
Sometimes_Lucid
Guest
Apologies if this has been asked before:
I am building an assembly and wish for one of the parts to be movable. I am trying to have a cylinder move inside of a slot. Basically a peg in a slot. The slot is through the body of a thin circular object(a circular plate). The slot is arc shaped and is at a constant radius relative to the center axis of the plate. I've tried to constrain the outside surface of the cylinder to the top surface of the slot(OD of the slot). ProE then constrains the center axis of the peg to the center axis of the circular plate. How do I constrain these so that that the peg moves inside the slot?
