PDMLink Rev, Version, Lifecycle State
  • Thread starter Thread starter kgwmu
  • Start date Start date
K
kgwmu
Guest
I am looking to use the PDMLink parameters on a drawing
for a family table of parts. I am looking to use
PTC_WM_VERSION or PTC_WM_REViSION in combination with
PTC_WM_LIFECYCLE_STATE. I can not get any of these
parameters to show up as choosable (might not be a real
word
)options while creating a family table. Is there
a config option or a setting that I should be looking at?
somebody must have tried this and figured it out
already...
Anything that begins with PTC_WM is controlled by PDMLink so you cannot edit those values manually.
If you want to report those parameters on a drawing you can do so with Repeat Regions.
It doesn't have to be a repeat region. You can use them in the format just like any other parameter. &PTC_WM_REVISION, &PTC_WM_REVISION, etc.
You have to remember these values will not be valid until the object is checked in for the first time. So, they may be blank, initially.
region.
manually.If you want to report those parameters on a
