C
CalManya
Guest
I have to export the drawing files to PDF and DWG including the revision level in the filename . (ex. FILENAME_REVISION.pdf). The revision level are defined as a paramenter into the model.
I would like to do this operation automatically, I mean, using a macro, or similar, export the active drawing file and forming theexported filename with the DRW filename plus the value of the parameter "REVISION".
Is it possible?
Thanks.
Is it possible?
Thanks.
