Patterns
  • Thread starter Thread starter hornj
  • Start date Start date
H
hornj
Guest
I have created a revolved protrusion that is grouped with a revolved cut, which I copied and created a revolved pattern. I had to redefine the cut and delete a line, but the pattern doesn
Shouldn't use copy if you intend redefining later.
Usually when you try redefining the sketch of feature thats been patterned you get the message cannot make additional references to 3 dimensional geometry or words to that effect.
Was your copied feature dependent or independent ?
This has been an issue with copying features in Pro/E for as long as I remember.
