M
mathfeel
Guest
I need to draw a couple if gears.
so basically I need to pattern something angularily
say i m drawing on the top datum...i would make a temp. datum at an angle to the top or right plane
and then I make a slice of the gear (like pizza) and pattern it this way...but I am keep on getting Pro/E patterning only a semi-circle instead the whole thing....I am a novice...can someone point me some thing I should know???
