O
Os2man4
Guest
I've patterned holes in my model by creating a series of geometry points in a sketch, creating a hole, and then patterning the hole using the Point reference. The only issue is that when I do that the first point that I create is created again when I make the pattern. So the first hole exists twice. Does anyone know any method or correcting this. Normally it would not be an issue, but when I go to create a hole table for the part drawing the hole shows up twice in the table and it just does not make sense from a manufacturing standpoint.
Thank you very much,
Jim
Jim
