patterning cuts
  • Thread starter Thread starter miked
  • Start date Start date
M
miked
Guest
I have a pattern of quilts with 85 instances that I would like to use to cut a solid. Is there an easy way to do this in WF2? I had thought I could use "solidify" but it won't work with my directional pattern. Whats the easiest way to pattern a cut?
Miked
Hi miked
I think you should use the FIRST instance of patterned quilts for cut. After this is easy to create Pattern -> Reference, Done for the solidified cut.
Andriy
Miked,
Here is something you can try.
I created a block. Then I created i surface that I wanted to solidify to remove material. Then I used the solidify feature to remove material.
Pattern the surface feature using directional pattern.
Use Ref pattern to pattern the solidify feature.
Thanks for the tips, I appreciate them.
What I ended up doing was redefining the first instance in my pattern as a solid cut and that did the trick.
miked
