Pattern-For Offest Feature
  • Thread starter Thread starter Maya
  • Start date Start date
M
Maya
Guest
Image file is being attached for reference
<?:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
I had developed the offset feature using area offset on revolved surface
I would like to Pattern the offset feature using axis A-6- But software doesn
I can't see your images. Upload your part if you can (legally).
The images are not visible. Pleaset try again
Heloo.....
Here I can see these pictures ....any way
So Please try ..Generate Reveloved Surface and on the top of revolved surface generate offset surface using area offset.Then apply pattern using axis normal to revloved surface....
That all what I did but failed tp patterned
Pics can't be seen. Posting links or uploading them?
I'm not following your explanation. What version Pro/E?
Is the following any help? Directional pattern shown.
(WF2) 2006-02-03_022211_prt0001.prt.zip
Helo Jeff
Thanks for all what you tried ...I would like to do Something like that
1-Insert -Generate Revolved circular Surface like a Ball on Front Plane.
2-Generate DTM 1 ,which is parallel to TOP and tangnet to circular surface
3-Generate DTM2 offset from DTM 1 at certain distance (not too much far) just outside the model
4-Edit -offset--from reference -selcet Expand Feature option
under Expand area -select Sketched region and define Sketch and Selcect DTM 2 for Sketching plane--In Sketcher Draw Hexagon on Centre--done
Now define offset value (like Extrude)
5-Generte Axis at intersection of TOP and Right Datum
6-Now Try Pattern the offset feature with the help of this generated axis
No Result for Pattren?????
Hopefully you have now got my point
All the best
I'll give it a shot and see what happens (may be later today). What comes to mind just now is the feature order (axis and offset). Seems I've had similar problems if the axis is newer than the feature to be patterned. Are any messages generated in message window to that effect?
... ok, had a chance to look.
2006-02-07_131540_tmp.zip (WF2, again)
Seems there are a couple of issues.
One is the axis; must be older than the offset so simply drag it up the feature tree.
The other might be a bug, not sure. Instead of creating an Expanded Offset, create a With Draft Feature Offset.
www.mcadcentral.com/proe/forum/forum_posts.asp?TID=26213&PN= 5 for more info on the surf copy method also attached. (You'll have to take the spaces that show up for who know's what reason out of the link.)
Helo...thanks for all that exercise..
I am unable to open your attached zip file in WF 2.0.
try again plz
i agree with that ...but dont know for other happening ..either a bug or what ever..
U may please guide me how Generate Football in Pro-E
