Part is there in parametric tree not visible.
  • Thread starter Thread starter chandresh19995.cy48@gmail
  • Start date Start date
C
Guest
I got into issue where my part is not hidden nor any error is there still i cant see the part please refer the below image for reference. 1626014125036.png
Double-check that the part is not Hidden. (use the Swap Space icon to see everything that is Hidden)
Select the plus on the tree to the left of your selected part. That will expand the tree for that component.
i checked there also, there is nothing
oh, I got the solution te dynamic section was enabled because of that. Thank you for your help. @MrCATIA and @ Rickyt
