PSSC
- Feb 11, 2008
- 63
I have a situation where the holes are 1/8" oversized on the diameter instead of 1/16" on vertical diagonal braces, back to back angles.
I have in the back of my head a memory that if only one of the plies were oversized, the connection could be considered a bearing type connection.
In this case if the angles were replaced with new steel with the correct size holes.
I cannot find anything to confirm this wisp of a memory but wanted to ask if anyone else had seen this in the manual?
This is probably a false memory but I thought I would ask.
