Hi all, I am working on some designs for overhead conduit supports in a seismic region (SDC D). The contractor is proposing to use Unistrut frames to support the conduit. The anchorage they are proposing is Unistrut P2073A Post Bases and Hilti HDA-PR M10 undercut anchors.
My concern: Per the Unistrut catalog, the post bases come with 3/4" bolt holes. The diameter of the M10 undercut anchors is about 3/8". Therefore, the holes are even beyond "oversized" for the anchors per RCSC Table 3.1.
The post base anchorage is subject to sustained tension and shear during seismic events. Am I correct in my understanding that using this combination of anchors and hole size is not acceptable, even if we use a large enough washer?
Modelling the post base in Profis, the only HDA anchor size that will work with the edge distance/anchor spacing dimensions of the post base is the proposed M10. The Unistrut Ohio site states that the post base has 3/4" mounting holes for 5/8" anchors, but this is perplexing as it doesn't seem any of Hilti's offerings that I'm used to specifying would work with the bolt dimensions of the post base.
It seems like I need to push for either welding plate washers, or using custom post base plates? Would slip critical connections also be an option here?
Any thoughts are welcome, thanks in advance.
