especial,
If I understand correctly you were able to get the exact same section to regen both with and without the extra dimension when intent manager was turned off?
lcoates68,
I too thought that perhaps the section wasn't properly joined and that was causeing the open section warning. However, according to analysis the distance between the end points was zero. I deleted and redrew the lines; same thing. The real kicker is that when I saved the section and then brought it back into a new part using Insert > Data from File it worked just fine.
I can only conclude that this is a nasty BUG in Sketcher that I've bumped into on several occasions and wasted a ton of time thinking I was doing something wrong.
I'm still working in 2001, I'd be interested to know if this is fixed in WF.
Bernie Hayden
XKL LLC
