Woosang
Aerospace
- Dec 18, 2009
- 48
Hi all,
I need your advise.
Please have a look at Y14.5 - 2009 Fig. 4-46. I will not talk about the customized DRF so let’s modify some features.
- Datum feature B is not a square cutout, it is a round hole with perpendicularity control w.r.t. Datum A
- Datum feature C is same as original feature, except that its DRF was customized.
- 3X hole is tagged with two single segment position control.
- DRF identification is same as original figure. Design intent requires one axis of DRF to be offset from datum feature C.
Case 1: 3X hole position upper segment is TP|∅0.5|A|B|C and lower segment is: TP|∅0.2|A|B.
Now what would the lower segment tolerance zone look like? Zone H or Zone V?
Case 2: Upper segment is same as 1st case and lower segment is: TP|∅0.2|A|C.
(again, DRF's are not customized)
I need your advise.
