Operable Mechanical Louvres
dik
26,056
Does anyone have a good approx weight of electrically operable extruded aluminum mechanical louvres in psf? The sizes are approximately 6'x9' and they have to function in a cold environment. The adjacent building walls are substantially covered with them... approx 75%. I'm planning to trim the ROs with CFS channel sections as opposed to rolled channels. Any problem with that approach. I've asked for loading and support requirements without success. The non-louvred parts of the wall are prefinished metal siding on CFS studs, with the lower floor walls supporting brick veneer. [ponder]
