Open file mode in AutoCAD 2007
  • Thread starter Thread starter Barto
  • Start date Start date
B
Barto
Guest
I want to set the open file mode in AutoCAD 2007. As now it has been set to open file from the command line, I want to change the way to open file from Windows "Open" pop-up dialog box. Any suggestions and help would be greatfully received.
Try these. "To resolve the issue type Filedia at the command line and set the value to 1. There is also the cmddia variable to enable command dialog boxes (if your missing these)."
Hi Barto,
Set FILEDIA variable on.
Enjoy!
