O-Ring size differences in an Assembly
  • Thread starter Thread starter pjsmith
  • Start date Start date
P
pjsmith
Guest
I would like to have an O-Ring with the same PN# XYZ to have two different Inside Diameters in a Assembly. Does anyone know how to write a relation that will control the I.D.'s of the O-Ring in the assembly? One of the O-Ring's is in a sub-assembly of the Top Level while the other O-Ring is directly in the Top Level assembly.
An o-ring can have as many different sizes for as many different locations it's used in.
My recommendation is to family table it, use the installed dimensions and create an instance for each location it's used in, eg:
12345678 Generic
12345678_891011-1 One instance used in 891011 assembly
Always good to include a counter (-1) as you may have multiple instances in a single assembly..
dougr,
How do you handle the BOM when you this method?
Charles
The BOM can become a problem with instances from family tables. If you're on Wildfire the flexible component functionality finally gets you what you really need to handle these types of situations.
Never had to handle the BOM, always been handled seperately because of reasons like this..
charleskim,
We use Intralink and have a user-defined attribute called Title.
We just add this to the family table and can then give each
instance it's own, unique name to appear on the BOM in our
assembly formats.
I would assume the same would work for a system-defined
attribute but have never tried it.
Brad
Brad,
The way you describe, you can not get the quantity to show up on BOM using report quantiy or can you?
Charles
charleskim,
The way we change the name of a component and/or an assembly is to add a repeat region relation to the BOM. If you can access PTC's knowledge base, see this link - http://www.ptc.com/cs/tpi/35714.htm or send an e-mail and I will give you more detailed instructions.
Best Regards
Patrick
Charles,
The attached ZIP file contains a JPEG image of a BOM on
on of our Pro drawing formats. The last item in the BOM
is an instance of a generic used four times in an assembly.
The title parameter allows different lenghts to show on the
BOM and the BOM created with Pro/REPORT in our formats
captures the quantity.
Hope this clarifies.
Brad
The focus is not to change the component or the part number that shows up in a repeat region BOM, not the part name. This situation is characteristic of other parts that may also change shape as a result of assembly or manufacturing process, i.e. rivets, bends, springs, but in this case it's o-rings. The technique I use was created by another manufacturer in our area. I learned it from them at a user group meeting.
It's called Physical & Phantom modeling. First the Physical Model (PN#x010_xxx)...is the O-Ring that will control the drawing. This mdoel has all the required dimensions and tolerances per the application and in it's purchased state. This model also has a family table. The table has the original part number (X010_xxx) with underscore_extensions for example
x010_176, x010_190, x010_202 which the extensions represent the changes in the I.D. of the O-Ring. These models get assembled into the assembly. Then the Phantom Models. The phantom models are created for one purpose and
one purpose only. To have the correct PN# to which the parts are order through our purchasing department show up on the BOM. This model named phantom_X010 has a family table with only one member. The member name is X010...the correct PN# of the o-ring. The model consists of a revolved
surface the same x-sec and i.d as the assembled o-ring and is assembled in the exact location as the physical o-ring. Then you just remove item ex.(x010_176) from your repeat region and your left with the x010 part in the BOM.
P.S. I still need a solution to have the I.D. of the same o-ring part number be different when assembled to one sub-assembly and have the I.D. of the o-ring different in the top assembly.
