NxOpen How to get ViewAlignment.Name of a specific view 1
Halasox
16
I am trying to get the view alignment names of a view and then delete the associated alignments. I am currently doing it by known names but would like to avoid this due to possible issues if the views numbering changes ...
I understand that I need to use ViewAlignment.Name to get it, but not sure how!
Code:
    Dim viewAlignmentBuilder1 As NXOpen.Drawings.ViewAlignmentBuilder = Nothing
    viewAlignmentBuilder1 = workPart.ViewAlignments.CreateViewAlignmentBuilder()
    Try
        Dim viewAlignment1 As NXOpen.Drawings.ViewAlignment = CType(workPart.ViewAlignments.FindObject("ViewAlignment 1"), NXOpen.Drawings.ViewAlignment)
        viewAlignmentBuilder1.SelectedAlignment = viewAlignment1
        viewAlignmentBuilder1.DeleteCurrentAlignment()
        nXObject1 = viewAlignmentBuilder1.Commit()
        Dim viewAlignment3 As NXOpen.Drawings.ViewAlignment = CType(workPart.ViewAlignments.FindObject("ViewAlignment 3"), NXOpen.Drawings.ViewAlignment)
        viewAlignmentBuilder1.SelectedAlignment = viewAlignment3
        viewAlignmentBuilder1.Destroy()
        Catch ex As Exception
    End Try
The ViewAlignment.Name will be blank unless you have specifically given a name to the object. The "ViewAlignment 1" and "ViewAlignment 3" shown in your code above is probably coming from the journal identifier.
The part has a .ViewAlignments collection that you can iterate over and get each alignment object.
Code:
Option Strict Off
Imports System
Imports System.Collections.Generic
Imports NXOpen
Imports NXOpen.UF
Module report_view_alignments
    Dim theSession As Session = Session.GetSession()
    Dim theUfSession As UFSession = ufsession.GetUFSession
    Dim lw As ListingWindow = theSession.ListingWindow
    Sub Main()
        If IsNothing(theSession.Parts.BaseDisplay) Then
            'need at least 1 open part
            Return
        End If
        lw.Open()
        For Each tempAlignment As Drawings.ViewAlignment In theSession.Parts.Work.ViewAlignments
            lw.WriteLine(tempAlignment.JournalIdentifier.ToString)
        Next
        lw.WriteLine("")
        lw.Close()
    End Sub
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
        'Unloads the image immediately after execution within NX
        GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately
    End Function
End Module
www.nxjournaling.com
