NutAce
- Apr 22, 2010
- 1,192
Hey all,
I have a large assembly with 2 arrangements. "Default" and "Interior"
I create for this assembly a drawing (mastermodel) where I place a number of views (using the Base View command).
I then place a view (Base view) for which I want to select Arrangement "Interior".
I can actually make that selection but when I place the view on the Drawing it shows the Default Arrangement.
After placing, when editing the view, it doesn't give me the option to change the arrangement . According to Siemens it should even be possible to change it with the Right Click context menu.
Same behavior when i place the view with the "View Creation Wizard" except that I afterwards DO get the option to change the arrangement. unfortunately also here it doesn't update the view to the desired arrangement.
Anyone else noticed this behavior? I already created a call at GTAC for this.
Everything is created in NX12.0.2 in a mannaged environment with Teamcenter 11.5 patch 2
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
Building new PLM environment from Scratch using NX11 / TC11
NX9 / TC10.1.2
