NX measuring all parts in assembly
ppeterx
Industrial
SK
i found following journal from Cowski on this forum. Im using NX 10.0.3.5 MP14. Its exactly what i want (it measures all parts in assembly and dimensions write in parts attribute), but in some cases dimensions isnt correct. Can someone give me a clue where is problem with this journal? Many thanks for your answers.
Code:
Option Strict Off
Imports System
Imports System.Collections.Generic
Imports NXOpen
Imports NXOpen.UF
Imports NXOpen.Assemblies
Module Module3
    Public theSession As Session = Session.GetSession()
    Public ufs As UFSession = UFSession.GetUFSession()
    Public lw As ListingWindow = theSession.ListingWindow
    Sub Main()
        Dim workPart As Part = theSession.Parts.Work
        Dim dispPart As Part = theSession.Parts.Display
        lw.Open()
        Dim myAsmInfo As New NXJ_Assembly_info
        myAsmInfo.Part = dispPart
        For Each temp As Component In myAsmInfo.AllComponents
            lw.WriteLine(temp.DisplayName)
            lw.WriteLine(temp.ReferenceSet)
            Dim tempBody As Body = GetCompBody(temp)
            If IsNothing(tempBody) Then
                lw.WriteLine("no body")
                lw.WriteLine("")
                Continue For
            Else
                lw.WriteLine("body tag: " & tempBody.Tag.ToString)
            End If
            Dim compBodyDims As New List(Of Double)
            compBodyDims = BodyBounds(tempBody)
            lw.WriteLine("X: " & compBodyDims.Item(0).ToString)
            lw.WriteLine("Y: " & compBodyDims.Item(1).ToString)
            lw.WriteLine("Z: " & compBodyDims.Item(2).ToString)
            lw.WriteLine("")
            PartStringAttribute(temp.Prototype.OwningPart, "X", compBodyDims.Item(0).ToString)
            PartStringAttribute(temp.Prototype.OwningPart, "Y", compBodyDims.Item(1).ToString)
            PartStringAttribute(temp.Prototype.OwningPart, "Z", compBodyDims.Item(2).ToString)
            compBodyDims.Sort()
            Dim bounds As String = compBodyDims.Item(0).ToString & " x " & compBodyDims.Item(1).ToString & " x " & compBodyDims.Item(2).ToString
            PartStringAttribute(temp.Prototype.OwningPart, "Bounds", bounds)
        Next
        lw.Close()
    End Sub
    Function GetCompBody(ByVal theComp As Component) As Body
        'return the first solid body found in the component's reference set
        Dim refSetName As String = theComp.ReferenceSet
        Dim thePart As Part = theComp.Prototype.OwningPart
        If refSetName.ToLower = "empty" Then
            Return Nothing
        End If
        If refSetName.ToLower = "entire part" Then
            For Each tempBody As Body In thePart.Bodies
                If tempBody.IsSolidBody Then
                    Return tempBody
                End If
            Next
            'no solid bodies in part
            Return Nothing
        End If
        For Each theRefSet As ReferenceSet In thePart.GetAllReferenceSets
            If theRefSet.Name = refSetName Then
                Dim refObjs() As NXObject = theRefSet.AskAllDirectMembers
                For Each temp As NXObject In refObjs
                    If TypeOf (temp) Is Body Then
                        Dim theBody As Body = temp
                        If theBody.IsSolidBody Then
                            Return theBody
                        End If
                    End If
                Next
                Return Nothing
            End If
        Next
        'reference set not found
        Return Nothing
    End Function
    Function BodyBounds(ByVal theBody As Body) As List(Of Double)
        Dim bbox(5) As Double
        Dim X As Double
        Dim Y As Double
        Dim Z As Double
        Dim boundingDims As New List(Of Double)
        'get solid body bounding box extents
        ufs.Modl.AskBoundingBox(theBody.Tag, bbox)
        ' msgbox ("min X: " & bbox(0) & " max X: " & bbox(3) & vbcrlf _
        ' & "min Y: " & bbox(1) & " max Y: " & bbox(4) & vbcrlf _
        ' & "min Z: " & bbox(2) & " max Z: " & bbox(5) & vbcrlf & vbcrlf & _
        ' "X dim: " & bbox(3) - bbox(0) & vbcrlf & _
        ' "Y dim: " & bbox(4) - bbox(1) & vbcrlf & _
        ' "Z dim: " & bbox(5) - bbox(2), vbokonly)
        X = bbox(3) - bbox(0)
        Y = bbox(4) - bbox(1)
        Z = bbox(5) - bbox(2)
        boundingDims.Add(X)
        boundingDims.Add(Y)
        boundingDims.Add(Z)
        Return boundingDims
    End Function
    Sub PartStringAttribute(ByVal thePart As Part, ByVal theTitle As String, ByVal theValue As String)
        Dim markId1 As Session.UndoMarkId
        markId1 = theSession.SetUndoMark(Session.MarkVisibility.Invisible, "part attribute")
        Dim objects1(0) As NXObject
        objects1(0) = thePart
        Dim attributePropertiesBuilder1 As AttributePropertiesBuilder
        attributePropertiesBuilder1 = theSession.AttributeManager.CreateAttributePropertiesBuilder(thePart, objects1, AttributePropertiesBuilder.OperationType.None)
        attributePropertiesBuilder1.IsArray = False
        attributePropertiesBuilder1.DataType = AttributePropertiesBaseBuilder.DataTypeOptions.String
        attributePropertiesBuilder1.Title = theTitle
        attributePropertiesBuilder1.StringValue = theValue
        Dim nXObject1 As NXObject
        nXObject1 = attributePropertiesBuilder1.Commit()
        Dim nErrs1 As Integer
        nErrs1 = theSession.UpdateManager.DoUpdate(markId1)
        attributePropertiesBuilder1.Destroy()
    End Sub
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
        Return Session.LibraryUnloadOption.Immediately
    End Function
End Module
Public Class NXJ_Assembly_info
#Region "Private Variables"
    Private Const Version As String = "0.2.0"
    Private _theSession As Session = Session.GetSession()
    Private _theUfSession As UFSession = UFSession.GetUFSession
    Private _components As New List(Of Assemblies.Component)
    Private _uniqueParts As New List(Of Part)
    Private _allComponents As New List(Of Assemblies.Component)
    Private _allUniqueParts As New List(Of Part)
    Private _notLoaded As New List(Of String)
    Private lg As LogFile = _theSession.LogFile
#End Region
#Region "Properties"
    Private _isTCRunning As Boolean
    Public ReadOnly Property IsTCRunning() As Boolean
        Get
            Return _isTCRunning
        End Get
    End Property
    Private _thePart As Part = Nothing
    Public Property Part() As Part
        Get
            Return _thePart
        End Get
        Set(ByVal value As Part)
            _thePart = value
            'Me.GetInfo()
            Me.GetAllInfo()
        End Set
    End Property
    Public ReadOnly Property AllComponents() As List(Of Component)
        Get
            Return _allComponents
        End Get
    End Property
    Public ReadOnly Property AllUniqueParts() As List(Of Part)
        Get
            Return _allUniqueParts
        End Get
    End Property
    Public ReadOnly Property Components As List(Of Component)
        Get
            Return _components
        End Get
    End Property
    Public ReadOnly Property UniqueParts As List(Of Part)
        Get
            Return _uniqueParts
        End Get
    End Property
    Public ReadOnly Property NotLoaded As List(Of String)
        Get
            Return _notLoaded
        End Get
    End Property
#End Region
    Public Sub New()
        lg.WriteLine("")
        lg.WriteLine("~ NXJournaling.com: NXJ_Assembly_info object created ~")
        lg.WriteLine("  ~~ Version: " & Version & " ~~")
        lg.WriteLine("  ~~ Timestamp of run: " & DateTime.Now.ToString & " ~~")
        lg.WriteLine("NXJ_Assembly_info Sub New()")
        'determine if we are running under TC or native
        _theUfSession.UF.IsUgmanagerActive(_isTCRunning)
        lg.WriteLine("IsTcRunning: " & _isTCRunning.ToString)
        lg.WriteLine("exiting Sub New")
        lg.WriteLine("")
    End Sub
    Private Sub GetAllInfo()
        'get all component info from assembly (all levels)
        lg.WriteLine("Sub GetAllInfo()")
        Try
            Dim c As ComponentAssembly = Part.ComponentAssembly
            If Not IsNothing(c.RootComponent) Then
                '*** insert code to process 'root component' (assembly file)
                lg.WriteLine("  part has components")
                '*** end of code to process root component
                lg.WriteLine("  calling GetAllComponentChildren")
                GetAllComponentChildren(c.RootComponent)
            Else
                '*** insert code to process piece part, part has no components
                lg.WriteLine("  part has no components")
            End If
        Catch ex As NXException
            lg.WriteLine("Sub GetAllInfo error: " & ex.ErrorCode)
            lg.WriteLine("  " & ex.Message)
        End Try
        lg.WriteLine("exiting Sub GetAllInfo()")
    End Sub
    Private Sub GetAllComponentChildren(ByVal comp As Component)
        For Each child As Component In comp.GetChildren()
            lg.WriteLine(child.DisplayName)
            '*** insert code to process component or subassembly
            If Me.LoadComponent(child) Then
                _allComponents.Add(child)
                Dim tempPart As Part = child.Prototype.OwningPart
                If Not _allUniqueParts.Contains(tempPart) Then
                    _allUniqueParts.Add(tempPart)
                End If
            Else
                'component could not be loaded
            End If
            '*** end of code to process component or subassembly
            If child.GetChildren.Length <> 0 Then
                '*** this is a subassembly, add code specific to subassemblies
                '*** end of code to process subassembly
            Else
                'this component has no children (it is a leaf node)
                'add any code specific to bottom level components
            End If
            Me.GetAllComponentChildren(child)
        Next
    End Sub
    Private Sub GetInfo()
        'get top level component info from assembly (no recursion)
        lg.WriteLine("Sub GetInfo()")
        Try
                lg.WriteLine("  calling GetComponentChildren")
                Me.GetComponentChildren(c.RootComponent)
            Else
            End If
            lg.WriteLine("Sub GetInfo error: " & ex.ErrorCode)
        End Try
        lg.WriteLine("exiting GetInfo()")
    End Sub
    Private Sub GetComponentChildren(ByVal comp As Component)
            _components.Add(child)
            If Not _uniqueParts.Contains(tempPart) Then
                _uniqueParts.Add(tempPart)
            End If
            Else
            End If
        Next
    End Sub
    Private Function LoadComponent(ByVal theComponent As Component) As Boolean
        lg.WriteLine("Sub LoadComponent()")
        Dim thePart As Part = theComponent.Prototype.OwningPart
        Dim partName As String = ""
        Dim refsetName As String = ""
        Dim instanceName As String = ""
        Dim origin(2) As Double
        Dim csysMatrix(8) As Double
        Dim transform(3, 3) As Double
        Dim curLoadOptions As UFAssem.Options
        _theUfSession.Assem.AskAssemOptions(curLoadOptions)
        Dim newLoadOptions As UFAssem.Options
        _theUfSession.Assem.AskAssemOptions(newLoadOptions)
        newLoadOptions.load_options = UFConstants.UF_ASSEM_load_as_saved
        _theUfSession.Assem.SetAssemOptions(newLoadOptions)
        Try
            If thePart.IsFullyLoaded Then
                'component is fully loaded
                lg.WriteLine("  component: " & theComponent.DisplayName & " is already fully loaded")
            Else
                'component is partially loaded
                lg.WriteLine("  component: " & theComponent.DisplayName & " is already partially loaded")
                lg.WriteLine("  attempting to fully load the part file")
                thePart.LoadThisPartFully()
            End If
            lg.WriteLine("  return: True")
            lg.WriteLine("exiting Sub LoadComponent()")
            lg.WriteLine("")
            Return True
        Catch ex As NullReferenceException
            'component is not loaded
            Try
                lg.WriteLine("  component not loaded, retrieving part information")
                _theUfSession.Assem.AskComponentData(theComponent.Tag, partName, refsetName, instanceName, origin, csysMatrix, transform)
                lg.WriteLine("  component part file: " & partName)
                Dim theLoadStatus As PartLoadStatus
                _theSession.Parts.Open(partName, theLoadStatus)
                If theLoadStatus.NumberUnloadedParts > 0 Then
                    If theLoadStatus.NumberUnloadedParts > 1 Then
                        lg.WriteLine("  problem loading " & theLoadStatus.NumberUnloadedParts.ToString & " components")
                    Else
                        lg.WriteLine("  problem loading 1 component")
                    End If
                    Dim allReadOnly As Boolean = True
                    For i As Integer = 0 To theLoadStatus.NumberUnloadedParts - 1
                        lg.WriteLine("part name: " & theLoadStatus.GetPartName(i))
                        lg.WriteLine("part status: " & theLoadStatus.GetStatus(i))
                        If theLoadStatus.GetStatus(i) = 641058 Then
                            'read-only warning, file loaded ok
                        Else
                            '641044: file not found
                            allReadOnly = False
                            If Not _notLoaded.Contains(partName) Then
                                _notLoaded.Add(partName)
                            End If
                        End If
                        lg.WriteLine("status description: " & theLoadStatus.GetStatusDescription(i))
                        lg.WriteLine("")
                    Next
                    If allReadOnly Then
                        lg.WriteLine("  'read-only' warnings only")
                        Return True
                    Else
                        'warnings other than read-only...
                        lg.WriteLine("  return: False")
                        lg.WriteLine("")
                        Return False
                    End If
                Else
                    lg.WriteLine("  component(s) loaded successfully")
                    lg.WriteLine("")
                    Return True
                End If
            Catch ex2 As NXException
                lg.WriteLine("  Load error: " & ex2.Message)
                lg.WriteLine("  error code: " & ex2.ErrorCode)
                lg.WriteLine("")
                If ex2.Message.ToLower = "file not found" Then
                    End If
                End If
                Return False
            End Try
            'unexpected error
            lg.WriteLine("  Error in Sub LoadComponent: " & ex.Message)
            lg.WriteLine("")
            Return False
        Finally
            'Reset assembly load option to the user's preference.
            _theUfSession.Assem.SetAssemOptions(curLoadOptions)
        End Try
    End Function
End Class
Three possibilities come immediately to mind:
[ol 1]
[li]The journal measures the first solid body that it finds in the used reference set. If there are multiple solids in the ref set, the measurement won't be correct.[/li]
[li]The .AskBoundingBox function used from the API states that it is not guaranteed to return the smallest possible bounding box. It sometimes trades some accuracy for speed of execution.[/li]
[li]The .AskBoundingBox function calculates a box aligned with the absolute coordinate system. If the longest dimension of the body is not aligned with the absolute X, Y, or Z axis, the calculated bounding box will be too big.[/li]
[/ol]
In the case of 1, the journal code would need to be updated to account for all the bodies in the ref set.
In the case of 2, the API offers a more accurate (but slower) version of the bounding box function.
In the case of 3, the journal would need some way of accounting for the shape/orientation of the solid body.
www.nxjournaling.com
Thanks for your reply. I have just one solid body in each part and body is aligned with coordinate system, so i think the problem is in accuracy of askboudingbox function. I have to look for some solution in API.
I forgot to mention that the name of the more accurate bounding box function is AskBoundingBoxExact. Also, there is the create box command available in interactive NX and through the API; it might be worth investigating.
