NX Drafting : Drawing Template Title box coming up in modelling, please help!!
vermatron
IN
Dear All,
I am new to NX. I am using NX 8. I am modelling a trolley. Modelling is complete. My drawing involves numbering each component to its drawing number. To achieve this I created a common attribute in each part which will have the drawing number. Since each part file contains the attribute, I put the drawing within each part itself (Now my drawings are in different part files) With this, now I can populate the BOM with quantity and drawing number in assembly drawing automatically. So far so good!
Now the problem is, in the top level assembly I can see drawing title block in modelling. Please check the attached pic for reference.
I tried to find the solution over the net, but couldn't find any. Please Help!
 https://files.engineering.com/getfile.aspx?folder=e21cd9ae-26ff-4f87-8298-7fdd8e87e4e4&file=Problem.png
From top level assembly go from modeling to drafting (if prompted do not select any sheet, just cancel it), you should be able to select the title block (and hide/delete it), if not go to layers and disable the visible only checkbox on layer 256 (default for title blocks)
This always worked for me, I hope it helps you too
Thanks a lot for your reply @gkravanja!
But these title blocks are coming up in other low level assemblies also also (My assembly is a multi level assembly). Anyway I'll try this and let you know.
It seems that your assembly is wrong. Anyway try to change the reference set to model for all component.
Didier Psaltopoulos
Dear gkravanja, it did not work :-(
Hi DidierPSICAD, thanks for your reply! Could you please let me know how my assembly is wrong ? Also I am using NX 8 and I don't know much about reference sets. By changing the reference set to model, did you mean to change the reference set to entire part because I can see only two reference sets "Empty" and "Entire Part".
Search for the reference sets command, where you can create a new one and add only the objects you want to see in an assembly context
Hi All,
I have observed that the title block table including the locked cells of the model are coming in the assembly which has this model as drafting annotation. Now in this assembly modelling, when I hide drafting annotations, this goes away, but when I go back to drafting (for the assembly) the same title box is missing there, all other parts of the template are intact. Could something be wrong with the templates ? I created these templates.
I had put all the curves and tables in the template under layer 256. The table has fields which can be populated. Could there be something that might have went wrong in while creating these templates ?
Create a very simple assembly using the Siemens OOTB templates - that way you can work out if your template is the cause.
Hi vermatron,
If they are not confidential, don't hesitate to share your assembly parts.
It will be more easy for us to help you
Didier Psaltopoulos
@DidierPSICAD
Sure, please find assembly in the attached archive.
Ignore the files inside 'New Folder'
Drawings are there in the following files :
Main Assembly __ASSY3.prt
Sub Assembly Level 1
base_assy.prt
base_frame2_assy.prt
base_frame3_assy.prt
Sub Assembly Level 2
saddle_assy.prt
pillar_female.prt
pillar_male.prt
pillarPlate.prt
Looking forward to hear from you.
Thanks a lot!
 https://files.engineering.com/getfile.aspx?folder=53b82f78-c366-4139-846c-0eae9ff575f9&file=Assembly-to-eng-tips.rar
@deedub777
Thanks for your reply! I'll try that too and let you know.
Sorry, but I was at customer site last week.
I don't have NX8 anymore and I tried with NX8.5.
I have no issue. Could you send more screenshots ?
Didier Psaltopoulos
