NX 11 - Combine Drawing
Guu
Automotive
Jun 5, 2019
Refering from this thread :
I already follow the method and able to combine multiuse 2D Drawing view into a single view.(2D of the same part)
But the dimension and annotation can't be copy with the method.
Does someone know the method to copy all the dimension and annotation with the view.
Thank you
Did you follow the description strictly or did you try a shortcut ?
It should work if you use the File-Export-part as described but i doubt that you can Copy/Paste sheets.
Tomas
Thank you for your reply
I follow the description properly and already success with import view.
But the problem is the dimension of the exported file is missing. (Update:The annotation is already work but need to relink)
Guu
