Nonliner analysis finite element stresses
lakasa
Student
Jun 20, 2011
9
I had model a vertical runner profile S350SD...which exceed the von mises stress limit 350MPA using elastic analysis/Linear material. Which then i shifted later to nonlinear material for plastic analysis ..Shows now von mises stresses equal to yield stress (does it means safe?). My question is when i can say the design is safe...which parameter shall i compare to satisfy the results..So that the checker can approve it.Is it strain?
 https://files.engineering.com/getfile.aspx?folder=89d5c29e-22b4-4b0c-8d73-264f82e4a5b1&file=FE_Results.png
If a plastic hinge developed at the location that has yielded, would your structure be ok ?
What software ?
If your material curve is elastic-perfectly plastic then strain won't mean anything.
It sounds to me as though your structure has failed.
Well once you leave the elastic range you need to look at the strain as control parameter
It depends on codes but usually 5% strain is allowed
