JStructsteel
Covered deck roof to existing. Attached is my detail. Since trusses are not same spacing as rafters, was going to use a nailer board into the top of the trusses. To transfer the load down, 2x blocking at each truss to the bearing.
See any issues with this? Roof is about 15' out from the house, so not alot of load, 20 psf snow, wind load.
If I go higher up on the roof, what options would I have to reinforce the trusses without a major analysis/rework?
[URL unfurl="true"]https://res.cloudinary.com/engineering-com/image/upload/v1694265656/tips/Roof_Connection_9-8--23_bxpsyp.pdf[/url]
