New Desktop Computer Specification
  • Thread starter Thread starter proengesk
  • Start date Start date
P
proengesk
Guest
Hello to everyone!
I urgently need a new hardware to install and use Pro-Engineer Wildfire 4.0 CAD-CAM modules.I will only use partmodelling, drafting, assembly modules for CAD.And
Get the best machine your budget can afford but consider these 3 things.
  1. <LI>Pro LOVES RAM</LI>
    <LI>Pro need video power don't skimp on the video card.</LI>
    <LI>64bit is the way to go because of 1. above</LI>
Whatever the machine you choose always keep the above item in mind. Get as much ram as you can afford with 4gb as a minimum. With a 32bit machine that is the most you can use but with 64bit that number increase considerably. Not all video cards are good Pro video cards.This especially applies to gaming video cards no matter how much memory they have.
Wray
