E
especial
Guest
I hope this is the forum for this questions.
I have cable/dsl router, hp printer with print server, two computers, one proe seat and one dsl line. One computer is setup the way it needs to be. Second computer (proe seat) need to see printer, outside world and first computer.
The problem is when I go to My Network Place>Properties>Local area Connection>Properties>Internet Protocol (TCP/IP)>Properties and select Obtain an IP address automatically. This is to be able to see outside world and printer. Proe needs to be Use the following IP address numbers or proe wouldnt open. See my problem.
Question do I need two ethernet card?
Question how do I add a second IP address or what is the solution?
TIA
AS
TIA
AS
