Ron247
- Jan 18, 2019
- 1,153
I am looking for information or articles about moisture that gets trapped in roof systems due to insulation causing problems. Examples would be a shallow parallel chord wood truss roof with un-vented insulation under the trusses. I have seen pictures of wood rot and rust on nails due to excessive moisture trapped in system. This would not be from roof leaks. This would be moisture forming in the area. I am told this is more of an issue on the west coast than the east coast for some reason I do not know.
Also, is there any moisture issues from the standard PEMB vinyl backed insulation that is placed over the purlins before the roof panel is installed. I have never seen a moisture problem from that but I have been asked by someone about it.
