Need help with a simple compression test
Junaid798
GB
I have a cube shape and I am trying to compress it by making the top plate move down at a speed of 1mm/s for 10 seconds (so 10mm total displacement) and then to get a stress vs displacement plot. I understand to get the plot I will need to have an output history request for displacement of the top plate, and one for the von mises stress of the cube. However I do not understand where I am going wrong with my model as it doesn't seem to do what I am trying to get it to do.
I am currently confused as to where to go from where I am right now and would appreciate any help as I am a beginner.
Thank you.
Link to image of assembly:
Link to input file:
You made a mistake in amplitude definition. If you want to get maximum displacement of 10 mm you should fill the table like that:
TIME —— AMPLITUDE
0 —— 0
2 —— 0.2
4 —— 0.4
6 —— 0.6
8 —— 0.8
10 —— 1
instead of:
TIME —— AMPLITUDE
0 —— 0
2 —— 2
4 —— 4
6 —— 6
8 —— 8
10 —— 10
Because displacement BC multiplies its magnitude by amplitude so when your magnitude is 10 it will be 100 at the end.
So with my step time being 10, does that mean using your amplitude table it will be do 1mm every second?
Yes.
P(t) = A(t) x F
Applied load at current increment time = Amplitude at current increment time multiplied with Magnitude (load definition value)
Look at the data you define and you will directly know when what value is applied.
