NEC 220.56 kitchen equip. demand factor to walk-in cooler/freezer
Designer_82
62
I'm working on a supermarket project that has a bunch of walk-in coolers/freezers for storage and clear glass displays.
Do you normally apply 220.56 kitchen equipment demand to the above or just go conservative and use 100% demand?
Consider the consequences if you are too low on your demand factor and the service won't handle the load.
The code is not a substitute for good engineering or common sense.
Ohm's law
Not just a good idea;
It's the LAW!
