My rendered animations are "sliding" around.
  • Thread starter Thread starter gregl
  • Start date Start date
G
gregl
Guest
Everytime I render an animation mpg, the entire assembly slides around. It's almost like it knows its sitting on the floor of the room.
A similar problem like this was posted almost a year ago, so I'm seeing if anyone has come up with a new solution.
My ground part is default assembled to the assembly. I've also done it assembled plane by plane.
Any thoughts??????
IN THE PHOTORENDER/ROOM EDITOR MENU, CLICK ON THE ROTATE TAB AND CHECK THE 'LOCK ROOM TO MODEL ROTATION BOX. THIS SHOULD STOP THE MODEL 'VIBRATING' WHEN YOU RENDER THE MOVEMENT.
HELLO
THIS IS STILL A PROBLEM
AS PTC CLAIMS THIS PROBLEM WILL BE SOLVED IN WILDFIRE (DATECODE 2002450)
KARAVASILIS
