ANE91
- Mar 31, 2023
- 369
I’ve got 4 supports equally spaced roughly 7 feet apart. This is near the max length a contractor can readily source, so I often end up with random cuts, cantilevers, and discontinuities. Even when I’m lucky and the contractor has somewhat nailed and clinched the plies together, the “splices” are incorrect.
Are there best practices for specifying these beams and explaining the important bits to the contractor (e.g., staggering the joints, using straps instead of nails, etc.)? Think basement ceiling (residential).
