multi shaft select and change there revolution angle
Arun_Gopala
New member
Apr 20, 2020
7
I am having a part with several shaft features,I am trying to select the shaft angle and chage its angle and loop through all the shaft features in the part.In doing so I am getting an error in "object doesn't support this property or method (objSel.Item(i).FirstAngle) see below teh code.Thanks for your help
Sub CATMain()
Dim objSel As Selection
Set objSel =CATIA.ActiveDocument.Selection
objSel.Search("type=Shaft*,all")
objcount = objSel.count
msgbox objcount
Dim i As Integer
For i = 1 to objSel.Count
dim angle1 as length
set angle1 = objSel.Item(i).FirstAngle
angle1.value=114.0000
Next
End Sub
you are still in selection object, to get to the item, you need to call objsel.item(i).Value.FirstAngle
regards,
LWolf
Dear LWolf,
Yep you are right, I need to call (Value).Thanks for your help.very much appreciate it.
Arun
