motor
Thuba
Chemical
Nov 21, 2024
44
goodday, my plant flow diagram state l require 10HP compressor. Does it mean any 10HP compressor will work or l need further information?
There is a lot more into selecting the right compressor for an application other than the horsepower. As follows:
The flowrate required at differential pressure (discharge minus suction pressure), inlet/discharge temperatures and pressure ratios and other properties of the gas being pumped, with all inlet and outlet process data of the fluid.
What type of compressor for the application is required such as a centrifugal or reciprocating.
What special features or auxiliaries are required for the compressor for the application.
What materials are required for compatibility with the process fluid.
Normally a purchase specification with data sheet is provided to a vendor that specifies all specific requirements of the compressor to be purchased in regards to performance requirements, auxiliary/accessory requirements, and material requirements, as well as what industry standard the compressor needs to be built to. The mechanical engineer and process engineer would provide the above data to the vendor, while the electrical engineer will provide requirements and specifications for the motor.
Thank you for your help. Unfortunately l am new to process engineering and l only have the plant flow diagram as attached showing that l need 7.5Hp motor and no further information. We use compressed air to dry cake filter after filtration using the horizontal pressure leaf filter. we blow the filter with 2-3bar compressed air. So was wondering if any 7.5bar centrifugal pump stated by the designer will do the job sufficiently. And if l were to install a lower hp, does it make any good engineering judgement.? Thanks again
Short answer is no.
Longer answer is that any pump or compressor you need to know certain things in order to size it or buy it.
These are
  • Fluid and it's properties (density, MW, compressibility, heat capacity etc)
  • Inlet conditions (pressure, temperature)
  • Outlet requirements (pressure mainly, temperature comes from the pump or compressor)
  • Flowrate (volume per unit time or mass flow
  • Power depends on flow and pressure difference,
Pumps and compressors are really just energy transfer between incoming power (electricity) and the fluid moving with increased head or pressure.
For an air compressor you now know certain things, I.e. fluid, inlet conditions (atmospheric usually) and you have a minimum pressure.
You don't know flow.
Many air compressors come as pre packaged units, often with a 7 bar/100 psi accumulator.
So probably any 7.5kW air compressor would do the job if it supplies air at 7.5 bar.
Does that help?
So it appears you need a centrifugal air compressor that outputs about 2 to 3 bar. So the conditions of the suction air are known which is just atmospheric temperature and pressure. The discharge conditions are 2 to 3 bar. All you need to know now is the flowrate in standard cubic feet per minute (standard cubic meters per minute). There should be information somewhere in the plant operation manuals, etc. that provides the required air flow rate, or you could contact the leaf filter manufacturer and get them to recommend a flowrate based on the leaf filter model number. Then you can contact a centrifugal compressor manufacturer and tell them the discharge pressure, flowrate requirements, and application and they will recommend a compressor with required auxiliaries and accessories. Due to the heat of compression the air exiting the compressor will be hot so you may need a cooler on the discharge. Check with compressor manufacturer on estimated discharge temperature.
Speak to any of the following manufacturers for small capacity air compressors : Ingersoll Rand, Atlas Copco, Hitachi.
And it is crucial to know if the air must always be absolutely free from lube oil vapor or liquid droplets ( to avoid contamination of dry cake ) for this service
A gas compressor is not a pump - see your Uni textbooks
Thank you sir
t
Short answer is no.
These are
Does that help?
thank you for your assistance
Hi ,
To support your work.
As other said, pay attention to the risk of contamination. You may need to purchase an oil free compressor.
Pierre
  • Understanding Compressor Capacity.pdf
