monorail
nilaypathak
66
In PreEng building, main two trusses running along the long side of building. Monorail supported by weld plated on bottom cord of there trusses. Bottom cord of HSS is 3 X2 X.188 and plate is 3/8 X4X6 with two holes for monorail bolt connection.
Does HSS thickness in enough to safe transfer of load and weld that plate to HSS? Monorail rated for 2 ton
Thanks for your time.
Please find attached Photo too.
You need local help with that.
Hire a structural engineer.
Mike Halloran
Pembroke Pines, FL, USA
I am in between two structural engineers. One from inspection and testing agency, rcomended addtion work on that too handle desing load. And another engineer who design this, who has 20++ expreience.
Let's look at the good points. If you don't like the building very much, this might be a good way to demolish it.
You're adding a lot of heat to the bottom member of a truss. It's already tensioned from the Dead Load and whatever else it's supporting. So you're basically melting a portion of a member in tension. If it withstands the welding process, it might get notched. So now it's weakened by the notch.
As Mike said, hire a Structural Engineer. If he blesses this, you'll have someone to blame if it falls down.
Please tell me that image has been marked with a pen, and you didn't just weld through the paint.
Mike Halloran
My first question would be was the truss originally designed for a 2t moving load? Pre-eng buildings are typically designed for very specific loads and have very little reserve capacity. That mono-rail is clearly something a maintenance group added.
Brad
