A building I designed is currently under construction. The building is a 3 story office building with moment frames resisting lateral forces in one direction. During UT testing of the moment connections it was noticed that a beam had a defect in one of the flanges (I call shenanigans on how the beam made it all the way through to the field). The defect is a slab bubble that has produced a crack in the flange of the beam. The crack is about 3” long and penetrates about 5/16” into the flange of the beam.
I have never been privileged to deal with such an issue. The beam is in place and the contractor and the fabricator want nothing to do with replacing the beam. I have offered the solution of having the mill certify that the defect is local and will not have an effect on the integrity of the beam (once it is repaired). The mill refuses to give such certification.
How often does a beam slip through the fabrication process and make it out to the field with such a crack? Also, am I being overly cautious in worrying about the integrity of the rest of the beam?
Hopefully the picture link works:
