JoelTXCive
- Jul 24, 2016
- 933
I am working on some circular lift stations in the North Texas area. The lift station will bear at about ~27 ft below grade. From the bearing level upwards, my PI is ~58 and the PVR is estimated to be 6" inches (welcome to Texas)
The geotech is recommending water injection to moisture condition the top 10ft of soil. I have not done this before. (The other option is to remove and replace 10ft of existing soil with select fill)
I understand the moisture conditioning concept. Inject the soil so that it swells in advance and thus reduces the future PVR.
My question is:
Is this a permanent or temporary solution?
Doesn't the soil return to it's in-situ moisture content at some future date? Maybe 1 year later or 5 years later? If that happens, then aren't I back to the original 6" PVR?
I have not called the geotech yet, and would like to get some background info before I talk with him/her.
Thank you!
My question is:
Thank you!
