How do I change Text Height in Drawing (2001)? I have View A-A and I want A-A to be .25 height. Old style ModifyText Height {0:View}{1:A-A} and select {1:A-A}...
Select the text hold right mouse button and select properties, change the variable for height. Or select FORMAT/TEXTSTYLE and click desired text, and change the variable for height.
The advice from efishent only enables you to change the text height once the view caption has been generated automatically by Pro/E. There is a setting that can go in CONFIG.PRO which will establish A-A. Unfortunately, the words SECTION and VIEW will come out to be the same size as A-A.
