- Thread starter
- #21
S
scoutfai
Guest
joelewinski said:To avoid the twist, you WOULD need a second path to "guide" the corners.
You said you wanted to model a spring as shown in the picture you posted. We're all trying to get you to that point. You shouldn't ask a question regarding specific information and then CHANGE YOUR PARAMETERS after we answer you saying that it doesn't work. IT DOES WORK! We're NOT mind readers. How were we to know you were going to do something different than what you asked for?
Boy, you try to help...![]()
Ok, breath deep, slowly, slowly, . . . I'm better now.
Pardon for causing your uncomfortable feeling.
I was stated that the method does not do thing in a complete correct manner (to my sense at least, apparently every people has different point of view). I do not put it into the wrong category. I do not have a formal education in SolidWorks and thus I just posting what I was thinking. If those statements insult your seniority in SolidWorks I am truly sorry about it.
That method does produce a spring that looks identical to the spring shown in my pictures, if just viewed by naked eyes. That method, I would guess that, the spring (with circle) is still twisted, but only it is not visible by eyes. My purpose is to model the spring, later on I will put into COSMOSWorks, I do not know whether such a invisible twist (I emphasize, it's just a guess) will affect the accuracy of the result or not.
Furthermore, the most sophisticated CAD modeling in my point of view is the one which mimic the real world manufacturing. I believe when such a spring is manufactured, no such twist is produced.
The reason I change the circle to a rectangular, is merely to test whether this method does what I want to. Obviously, my requirement is different than your requirement and I am sorry that I did not state it clearly in the 1st post.
Nevertheless, I will still take that method as an acceptable option. But if a method was found that does not produce such a twist, it will be more preferred by me.
I agree with you, that a guide curve will be needed to avoid such a twist. Although I never try it before but I will beg that it is not an easy task. Again this is the reason I am searching for a method which does not cause twist and is simpler than creating another guide curve (which I believe is hard)
Edited by: scoutfai
