C
CarnigRing
Guest
Could anyone give me some tips on modeling bent wire products? I've been using simple intersect curves and sweeps so far. The problem is that this can get a little tricky to modify specific dimensions and is a bit unrealistic as it relates to the forming process. For example, something that should be a radius may actually be an ellipse in Pro. Additionally, it would be great to “unbend” the wire and find a starting length. Thanks in advance.
